What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
