Under your dash above the steering column there is a starting relay replace it. You can Google this and they will show you the exact location. New they cost about 100 dollars go to a salvage yard and pay under 10 dollars. One other suggestion first try this get a big hammer and hit your starter 3 or 4 times solid and then try to start the engine. Starter may be bad and hitting it will move the rotor to allow it to start. good luck.
Error 01 means that a previous activity has not been completed. Here is a link to the manual: http://totalpos.co.nz/wp-content/uploads/2012/10/Casio-TE2400-Operator.pdf
I'm curious on how you checked the key way. They cost about a dollar and I would change it anyway. The popping sound is typical of an out of time ignition. Thanks, George
"REG BUFFER FULL". This means you have rung up a large amount of items in one sale without finalising with a payment type. Normally, you can press CLEAR (C) and then press a payment type e.g CASH. If not, then you have overflowed it to the point of no return (just for this sale), so try this:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL and wait 5 seconds.
This should take you to program screen.
Now turn key back to REG and try it. You may have to log on again.
Note: This normally does not cancel all of the items in the sale, so they will still be on your daily report, but at least you get control back again. Next time, don't ring up so many items. Use tracking (tabs) for that.
To switch the radix point between the US and European modes, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
If the C indicator is displayed it reminds you that interests are compound interests. It it does not show, interests calculated are simple. To toggle between compound and simple interests, press the key sequence [STO][EEX].
1 Hit the date/time key above the cost key until the date shows 2 Hold down the M+ key until the first digit flashes 3 Enter date info with the numeric keys 4 Hit the M+ key to save
Time:
1 Hit the date/time key above cost key until time shows 2 Hold down the M+ key until the first digit flashes
3 Enter time info with the numeric keys
