Re: Hoover floormate fh40150 will not dispense cleaning...
Hi Dona! Your FloorMate should not be giving you any trouble. Can you please email [email protected] for further assistance? We have a couple questions.
Thanks!
? 0:41
https://www.youtube.com/watch?v=xGjXVx2lFPk
Aug 16, 2013 - Uploaded by Hoover
Are you having a problem getting your Hoover FloorMate to turn on? ... Hoover FloorMate Deluxe Hard Floor SpinScrub Cleaner- Review and Demo ... Kirby vacuum cleaner won't turn on dead; Douglas Vacuum & Allergy ...
Hi! The clean water tank may begin to leak if solution is stored in the tank. This can cause the rubber seal on the clean water tank to disintegrate. The tank will need to be replaced. To purchase a replacement clean water tank just follow the link below. Hope this helps!
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
