SOURCE: igniter will not shut off on my DCS RGS-366 gas range
spark generator is faulty usually - replace
SOURCE: RG 364 6D DCS gas range
Call 888-281-5698. Parts ship from California, available next day. I've had immediate, good, intelligent response.
SOURCE: DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
SOURCE: DCS RGS 366 range, oven will not do anything when I turn it on
Sounds like the electronic ignitor has gone bad. Here is DCS contact info, they should be able to direct you to a reliable service provider:
contact DCS Customer Service at (888) 281-5698. Before you call, please have the
following information ready:
Model Number (located on rating plate backside of kickpanel).
Serial Number
Date of installation
A brief description of the problem
Your satisfaction is of the utmost importance to us. If a problem cannot be resolved to your satisfaction,
please write, fax, or email us at:
Write:
DCS
Attention: Consumer Relations
5800 Skylab Road
Huntington Beach, CA 92647
Fax us at: (714) 372-7004
email: [email protected]
SOURCE: Place explain in detail how to get the door back
Turn the range off and let it cool completely.
is the whole unit dead???if so chk main panel in your home for pwr 120/240 volts and again at unit,then there are small electronic fuses to protect the control panel and could cause a no operation condition
