SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
SOURCE: coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
