In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Press and hold "MODE". Press MODE 2 times (after the first time, the
alarm time flashes, after the 2nd time, the second flashes). Press ADJ
to change seconds. Press ST/STP to switch from seconds to minute. Press
ADJ to change minutes. Then press ADJ to change hours. Press MODE when
done.
You can get instructions from the Amitron web site. Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated instructions.
Choose the one that looks like yours and download the PDF file
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at [email protected], or by phone at 1-888-459-0404.
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
