SOURCE: Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
SOURCE: gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
