RC Thomas the Tank Engine Logo
Posted on Oct 05, 2009
Thomas and friends replacement charger
Where can i buy a new charger for thomas the tank and friends ride on train with coloured track. the £100 set
5 Related Answers
Anonymous
  • Posted on Jan 22, 2010
SOURCE: Peg Perego Thomas Train Track Rider
ok I have a train the light and sound work, but the train does not move. Used alligator clips from battery direct to motor, then the motor runs. Just ordered a circuit, will post when receive circuit with sound 15.00.
Anonymous
  • Posted on Dec 26, 2008
SOURCE: where do i plug the charger into
The battery is probably located under the seat and will plug in there
Anonymous
  • 80 Answers
  • Posted on Mar 31, 2009
SOURCE: ride on thomas peg-perego
Sometimes the battery and/or the charger can go bad. If the battery is less than 6 volts on a multimeter, it won't operate for long. Is the headlight bright or dim? Remember that the button has to be held down to run. Releasing the button will stop the train.
If neither of the above works, you may want to order a new circuit board from tigerimports.com.
catief
  • 3 Answers
  • Posted on Apr 15, 2010
SOURCE: Thomas the train blue track layout
Try looking for your set here and downloading the manual
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
Anonymous
  • Posted on Nov 21, 2010
SOURCE: Looking for track layout instructions
find it here
http://service.mattel.com/us/product_detail.asp?id=R9634&Ntt=R9634&Pn=1&Brand=Fisher-Price+Friends&Cat=Thomas+The+Train+TrackMaster
Where can get extra track for Peg Perego Thomas the Tank ride on train
Currently, I can suggest only you contact peg-perego's uk representative Mamas & Papas at the address given on the following webpage
http://global.pegperego.com/toys-site/where-to-buy/
MAMAS & PAPAS LTD.
Colne Bridge Road
HD5 ORH HUDDERSFIELD WEST YORKSHIRE - UNITED KINGDOM
Phone: (44) 1484-438200
Fax : 1484-438210
Email: [email protected]
If they have anything you would like, I believe that delivery can be arranged, and you will not have to go to Huddersfield.
(http://global.pegperego.com site > support tells you how to contact UK rep.)
I suspect that track for the choo-choo model is compatible with what you are looking for (but that doesn't seem to be available at present either. You might try ebay, but be careful to check that you are buying exactly what you need.
21.July.2014
1helpful
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
I have the Thomas and Friends Trackmaster talking Thomas train. 2 days after I bought it he stopped working. I changed the batteries and now he only talks. He wont move on or off the track at all?
I brought one a few days ago and out of the box it talked but would not move. I returned it to the store for a replacement. I noticed that the back wheels under the on and off switch have weight on them before the train will move. If the train is not sitting on the track, it will not move, That is what makes thomas stop at the station
Where to find thomas the train instructions
on the box it should state manufacture contact them and ask for the instructions should be no problem
1helpful
The motorised chassis of our second-hand Tomy THOMAS THE TANK ENGINE Big Loader Train set is not working properly. The motor grinds away but the wheels don't turn. Does anyone have any pictures of the...
Hi I dont have a solution but found you can buy a new chassis from tomy uk for about 5 pounds. I also found a guy on eBay called thatwasfun who repairs tomy Thomas things for $10
I was given a thomas train and track set, but did not come with battery or charger. I need to know which ones to buy.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
4helpful
5helpful
3answers
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Top RC Toys Experts
NOEL
NOEL
john h
Are you a RC Toy Expert? Answer questions, earn points and help others
