Re: My handle on my bugaboo wont lock into place just...
Go to www.buggypitstop.co.uk speak to Fred they are the only people that repair the handle everwhere else they will tell you that it can't be repaired and you need a new replacement handle @ £270.00
This is not safe and you can call bugaboo, give them the number on your chasis and they will be able to help you. They will most likely replace since it is a big problem as it is the carry handle.
First check that the handle extension locks hold properly and the handle is not slipping on on side. A handle lock problem (the part that allows the handle to swing from back to front) should be obvious but check both are locking and have the same amount of play. Finally check all four wheels spin freely and the smaller front set can both rotate freely. Your Bugaboo maintenance kit came with a small can of silicon spray. Use it regularly (once every month or two) to lubricate the handle lock, brake lever and wheels. If you find a specific problem let me know and I'll try to help.
Turn stroller upside down (sans baby ;-) First spin each back wheel to check it turns freely and it's fully engaged into the chassis. Front wheels should spin easy and rotate 360. If this is all good check the handle locks, are both sides locked or is only one side locking causing the handle to twist and put uneven pressure on the chassis.
www.buggypitstop.co.uk are the only company that repair bugaboo handles.Highly recommended they will fix it at a faction of the price of a replacement handle
