IOGear (GBE201W7) Wireless Headset Logo
Posted on Dec 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iogear speaker problem
I have the iogear Z-GBE201W7 and suddenly I can no longer hear anything from the speaker. Everything else works fine.
Anonymous
Level 3:
President:
  • Master 2,923 Answers
  • Posted on Apr 07, 2009
Anonymous
Master
Level 3:
President:
Answers
2923
Questions
0
Helped
730604
Points
8409
To isolate the problem, here are the things that you may do for the GBE201W7.
1. Disconnect/reconnect it from the phone or other Bluetooth device.
2. Make sure that it's fully charged.
3. Increase the volume while trying to make a test call.
4. Contact IOGEAR Tech Support if you will get the same problem after trying the first 3 steps. Meaning, this headset needs to get repaired.
2answers
Where can you get updated firmware for GPSU21?
Support & Additional Contacts Support Phone: 866-946-4327 x4862 (7:00 am - 6:00 pm Pacific)
Support Email: [email protected]
Service Support (Latin America): [email protected]
Service Support (United States/Canada): Knowledgebase and Customer Support
Webmaster: [email protected]
General Info: [email protected]
Press Contact: [email protected]
They have an Admin Utility.
https://iogear.custhelp.com/app/answers/list/search/1/kw/firmware%20upgrade
No longer have installation disk. Where can I down load it
As you were not very descriptive, I found an area that gave the drivers for the specific device you listed and there are many operating systems that it is compatible with. Once you get the drivers installed it is simply just a matter of pairing the devices (the speaker and the object running the Bluetooth adapter) and you should be ready to go!
Drivers:
http://www.iogear.com/support/dm/driver/GBU421WM#display
Hope this helps
Toggle keys don't work as advertised
Hi David,
I located and downloaded a copy of the manual and found the details for [Scroll Lock] [Scroll Lock] [Enter] on page 8 that simply says:
"This will switch everything (KVM and sound) to the next port."
There is no mention of this keystroke switching to the next port "only if there is a computer connected" as you indicated in your question. It would seem to me that if the KVM switches to the next port when it receives the [Scroll Lock] [Scroll Lock] [Enter] keystroke - it is working as described in the manual that I downloaded from the IOGear site.
The only remaining commands accepted by the KVM are :
[Scroll Lock] [Scroll Lock] [a] [Enter] which is a 5 second Auto Scan mode
and:
[Scroll Lock] [Scroll Lock] [a] [n] [Enter] which is nearly identical as the a5 second Auto Scan mode - except the the numerical value you type in place of [n] is the number of seconds spent on the next port.
Double check your manual and if you're still having trouble - contact IOGear directly below:
Toll Free 866-9-IOGEAR (USA)
Phone: 949-453-8782
19641 Da Vinci, Foothill Ranch, CA92610
www.iogear.com
[email protected]
Recently , my computer has been locking up. I boot up and logon just fine , then in the middle of the screen the speaker symbol shows up with a blue bar indicating 100 %. The computer is completely inop...
Your computer is locking up because of a lack of memory resources. This is caused by having too many items in start up folder; virus programs are notorious for gobbling up tremendous amounts of computer power and leaving unit to operate at a crawl if at all. Get rid of all the junk you have running and you will be a happy camper.
4helpful
My iogear KVM switch will not toggle between machines
Try following the this link and see if it helps. It helps to explain how to connect the keyboard to the KVM since the keyboard port is the only port that will recognize the port switching commands.
http://www.iogear.com/support/faq/id/318
2helpful
Getting IOGEAR GPSU01 to work on Vista 64
If you know the IP address of the print server you can create a TCP/Ip print port. IOGear offers direction on how to create this type of port and here is a link.
http://www.iogear.com/support/faq/id/297
2answers
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
Iogear 4 port USB 2.0 HUB (Model GUH285) now working properly
I think it clearly states that the device is defective.... you need to call IOGEAR for RMA if its still under warranty
Iogear problem
Hi. What device are you using? I suggest that you check if the keyboard is hooked up to the correct port. You will see underneath the KVM an icon that looks like a mouse and a keyboard. Make sure that everything is hooked up correctly. It should be okay once you connect them properly. Press "scroll lock" twice.
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Top IOGear Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you an IOGear Radio Communication Expert? Answer questions, earn points and help others
