My DCS oven gets up to temperature fine and holds it fine, but it makes a ''pulsating'' noise or thumping noise while in use. Sounds like a midget in there pounding away trying to get out. Is this normal? I called a tech who suggested it was the metal expanding, but it doesn't sound like that at all.
SOURCE: DCS RGS 366 range, oven will not do anything when I turn it on
Sounds like the electronic ignitor has gone bad. Here is DCS contact info, they should be able to direct you to a reliable service provider:
contact DCS Customer Service at (888) 281-5698. Before you call, please have the
following information ready:
Model Number (located on rating plate backside of kickpanel).
Serial Number
Date of installation
A brief description of the problem
Your satisfaction is of the utmost importance to us. If a problem cannot be resolved to your satisfaction,
please write, fax, or email us at:
Write:
DCS
Attention: Consumer Relations
5800 Skylab Road
Huntington Beach, CA 92647
Fax us at: (714) 372-7004
email: [email protected]
SOURCE: Oven slow to heat
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
