Sentry Fireproof Safe Logo
Posted on Jan 23, 2008
Forgot Digital Combination of Sentry Safe Model #SO500
I have had a Sentry combination model number SO500 safe for the past eleven years and within the past year, I have forgot the combination. My question is if there is a master combination or if there are any other suggestions to locate my combination?
  • 16 more comments
  • v3martinez Feb 12, 2008
    I've never used the Sentry Save lock- I don't have the combination. I've tried to open it with the keys but unable. Can anyone help me open it? There is a little sticker on the side of the door that says:
    S3410
    AY319079*
  • Anonymous Feb 21, 2009
    after punching in number, green light comes on, but door will not open!
    HELP
  • Anonymous Mar 16, 2014
    lost sentry safe combination
  • Anonymous Mar 17, 2014
    Sentry gun safe model R2921
  • Anonymous Mar 19, 2014
    lost combination is open but i don't close it. dial only
    need to get a combination code, have serial number only
  • Anonymous Mar 21, 2014
    I have a fireproof safe that uses a keypad and key combination. I replaced the batteries and can see a light, but can't read where the numbers read and it won't open. Any suggestions?
    After replacing the batteries, I can see light. The numbers do not light up nor can I read the digital. I've tried pushing the numbers but none of them light up or show on the digital reading window. Nor will the safe open? Any suggestions?
    20 gun safe need comination form
  • Anonymous Mar 22, 2014
    HVE COMBINATION BUT ERROR MESAGE
  • Anonymous Mar 25, 2014
    sentry safe #1610
    I have two master lock combination locks that I have lost the combinations for. I have the serial numbers on the backs of them.
    forgot combination on p00sc
  • Anonymous Mar 27, 2014
    We lost the key and combination. I managed to pick the tubular lock, but don't have the combination. SN is AL030526* Is that combo on record?
    lost combination for sentry safe BD-474714*
  • Anonymous Mar 29, 2014
    An771102
  • Anonymous Mar 31, 2014
    forgot the number combination
    With combination
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Feb 08, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
12252
Points
29
Https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 14, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15063
Points
6
There should be a factory code that will work even if you have changed your personal code. You will need to contact Sentry Customer Services and they should be able to give you the code - You will need to fill in the details as listed at http://www.sentrysafe.com/customerCare/retrieveCombination.aspx and then send this in to Customer Services. If you are still have trouble (or there is too much of a delay) send it onto [email protected] - this is technically customer service for Europe but they might be able to help you anyway.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5960
Points
Have combination its getting harder to open 5 number digital scooter
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Model 1310. How do I recover from lost combination?
Sentry GroupFor over 80 years, SentrySafe has built fire-resistant safes that provide security ...Combo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership ... the notary process if you do not have your username, password, or combination. ... An override key is needed to unlock the safe.Missing: question
' Sentry® Safe ' SFW
SENTRY SO500 will not release and open. Combo is correct
From the Sentry Safe web site:
In order for Sentry Group to release a combination for any safe, we require a notarized request, stating that you are the owner of the safe (the last name of the notary public must be different than that of the safe owner). Please indicate how you'd like to receive your combination.Options include first class mail, e-mail or fax.Your letter must clearly indicate which method you are choosing to receive your combination, as well as the mailing address, e-mail address,or fax number to which it should be sent.Note that failure to indicate the method in which your combination should be returned to you will result in delays to the process.Please include the model number, serial number, and a $20 check or money order (please do not mail your credit card number), your address and telephone number.
Your request may be mailed to us at:
Sentry Group
Attn: Dept. 200 882 Linden Avenue
Rochester, NY 14625-2784
Please allow 7-10 business days, upon receipt of your request, to receive your combination.
This request may be faxed to us at : 585-381-2940.
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $20* money order on your fax (please allow 24 hours for processing your faxed request).
To pay by MasterCard or Visa please contact our Customer Service Department at 1-800-828-1438 (please do not fax your credit card number).
* Prices subject to change
3answers
Cannot open Sentry Safe #S3310
THERE IS NO WAY TO FIND IT .. IF POSSIBLE ASK THE RETAILER ABT THIS DETAILS..
I HOPE,THIS SOLVES YOUR PROBLEM
2helpful
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
1helpful
NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH WAY TO TURN AND HOW MANY REVOLUTIONS PAST NUMBERS SHOULD BE USED. i HAVE A OLDER SENTRY VALUE GUARD SAFE, MODEL # 1330
Locksmiths advise If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
1helpful
We forgot the combination to our Sentry Fire Safe Model 1610 HELP
Contact SENTRY
Sentry Group
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $15* money order on your fax (please allow 24 hours for processing your faxed request).
I have a sentry SO500. I know the combination but
A locksmith would try to replace the batteries. Sometimes you will get the green light but the batteries still will not have enough power to retract the latch.
2helpful
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
