Hi, my toast will not stays down when I push down the lever. I think the electronetmagnet gone out. Where can I get this part for this unit? Its modle is 2ng2us, 120vac, 900 watt, and its serial number is 2004.36. Thanks
I live in San Jose, Calif. and I'll try a couple websites you gave me. ThanksI live in San Jose, Calif. and I'll try a couple websites you gave me. Thanks
There is a toll free number at this website you gave me. I will give them a call tomorrow. Thanks.There is a toll free number at this website you gave me. I will give them a call tomorrow. Thanks.
You can't post conmments that contain an email address.
Here is the web site of the maker, you can contact them here http://www.dualit.com/ Dualit Limited County Oak Way Crawley West Sussex RH11 7ST t + 44 (0) 1293 652 500 f + 44 (0) 1293 652 555 e[email protected]
No you need to replace the heater of the second center since it heats only in one side, you can buy on ebay and they have instructions o how to replace it
It can be repaired.
There is a short circuit inside may be of dust gathering on contacts or the contacts are worn out due to prolonged use thus touching the heating coil or body some where inside. Smell coming is definitely burning of wires inside.
Open the toaster and you may be able to see the burning spot
remove from the electricity supply remove crumb tray, remove bottom 4 os 6 screws. at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!! put it back together abd try it if it does not work 4 slice toaster from Tesco £9.99
Two possibilities:
1:A wire has come off your toaster switch or plug top,shorted and blown the fuse, and all you would need to do was refit wire and replace fuse.or
2:The element has gone........probably cheaper to buy a new one
Hope I have resolved you question, but please leave positive feedback if so , as it still takes time to answer questions and it would just be nice to know if I have helped
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This is operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
