SOLUTION: step 1: make sure there is no dvd in the dvd player before you start fixing the problem. Step 2: Press the "setup" button on the remote. Step 3: Once you have removed the dvd from the dvd player it should allow you to go to "preferences" in the setup menu. So do that. Step 4: Go to "TV TYPE" and make sure it's on NTSC. And then exit setup by pressing the setup button once again. And it should work.
NEED MORE HELP: Hi, I'm having this same horizontal rolling problem. When I tried using the remote to fix it, I couldn't tell where to arrow down or across because I can't read the screen while it's rolling. Could you detail the steps so I can do it blind?
Either you should check the manual for the menu navigation to scroll blind or use the composite (rca) outputs of the player first then connect to your the composite input of your tv so you can see the instructions on the tv with out setting it to NTSC or Pal. Then after successfully setting the tv mode, you can reconnect the RGB video out cables...
Rolling in the sense? what you mean?
Koss Contact Information
Main support number1-800-USA-KOSS
Email support[email protected]
am trying for manual. mean time ask koss in help line for manual link. they may also help you mean time
i helped him in some way
but he rated me as inappropriate
please remove the inappropriate
Could you please describe the cables and connections? Cable colors? Connection locations? I don't have the manual. Thanks.
The horizontal hold is not holding.
