Hi There,
Please could you help,
I have the Tefal Elite Avante oven, and the LCD display does not work properly.
The oven works fine without this, would this mean it is just a bulb
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
If the oven is not working, the fan is not working, and the light is not working, it suggests that the oven switch is faulty as that is the only common part for all 3 things. It might be a broken wire or a faulty switch. You will need to dismantle the oven to gain access to the switch and then use a multimeter to test it. if you do not know how to do this, then get an electrician or oven repair company to help, as there are dangerous voltages inside an oven than can give you a shock or kill you.
What is the actual temp of the oven? Not what the display says? If the conveyor running normal? If so you just need a display board. Depending on what temp is there are many possibilties after that.
