Hate to ****** a post but i can't find anything close to what i am looking for i have the same exact machine but i did the white vinegar thing worked like a charm but i noticed that the heating element on the bottom will not heat at all is there a solution for this problem that i can do locally if not i will have no choice but to scrap it and i really like this coffee maker
Have you try this link? http://www.bunnomatic.com/pdfs/commercial/manuals/39338.0000.pdf
Hope this will help you
You can find there at page 10 the schematic diagram
hope this is what your looking for?
^_^
Check this site for more info.
Baby you will like this..
http://www.bunnomatic.com/pdfs/commercial/manuals/10860.0001.pdf
Hiya falcon18!
Unfortunately, the service manual or schematic you seek does not appear to be available online - a common occurance for small appliances. In my opinion, your best bet would be to give Bunn a call at
800-352-2866 (Business Hours apply) and see if they can take care of ya.
Click HERE for the service manual.
Goodluck..
There is no service manual available for your manual.The only solution is to contact them or send them an email and get one.
Main support number: 1-800-352-2866
Email: support[email protected]
Goodluck..
The email id is
home@bunnomatic.com
Email: [email protected]
Goodluck..
Wow...that's an interesting situation. Let's see what we can find in the world of wiring diagrams. Bunn makes a good machine, no doubts about it..
here's a link for manuals
that series does not appear on here, so there must be another model number somewhere..
falcon..you got a webcam? maybe an over the shoulder will help you out?
here's a neat video that this session reminds me of..
Please say the model number
here you go for manual
click here
thank you sir
good luck
dont forget to rate the solutions
I have photos of the unit wiring and can answer any further questions; please note, this unit has no heading pad for the pot.
There is a white wire (small round plastic insulators used) coming from one of the elements of the water heating unit, a black wire coming from the other along with a brown stripped wire coming from a slightly larger diameter plastic insulator that surrounds the one that the black wire comes from. There's a black wire coming from the thermostat (I assume it's the thermostat) and a blue wire that's grounded. There are 2 white wires that come up from the water heating cylinder (I assume to keep the water hot [rated 34W,120V]). The wires coming up from the switch are 1 white wire, 1 brown stripped wire, and a green ground wire.
Any further details needed, please let me know. Surely there's a diagram for this unit somewhere !! I can almost work out the way it needs to be connected, but I'd rather be 100% sure than throw a breaker and ruin a good coffee maker.
Thanks.
No, that's not the service manual, that's for a VP series unit which has a warming pad for the pot and isn't like the BT series. I already have this digram, that's why I said I can almost figure out how the unit should be wired, but I'm not 100% certain.
No, right on the bottom of the unit it says BT10-B; I downloaded the user manual for the coffee maker, which was:
38864.0000_BTX_U_C_English.pdf .
The diagrams listed are close, but that's not it.
No webcam but photos. The unit also says Thermofresh on the front.
The diagrams are close but not getting it.
I searched on the Bunn site listed given in the link, but can only find the user manual, not schematics.
And the model is BT10-B.
Thanks guys, I really appreciate it.
I'd almost have to call Bunn or find someone with the same unit that would be willing to pull the top.
I'll post a follow-up when the unit's working and back together.
No offense intended. Extremely helpful, but I've pulled up all this info already. I'm ready to just draw the diagram myself and get the thing back together. 'Had to make coffee in a pot this am :)!!
Thanks again, you all have been very, very helpful !!! All of you !
There is the white wire that goes to the element, black and brown come out from a thermistor(?) on top, and a black comes from the level indicator(?) with a blue grounded. 2 whites come from the side of the water tank that normally keep the water hot.
Thanks.
There appears to be no connection that goes to the other terminal, and it looks as though there never was a connection here; I thought possibly one end of the element was grounded, but my meter doesn't indicate this.
Many of the schematics are coming very close, but not quite.
I'm working right now trying to diagram this thing out, 'just haven't quite got it, because I'm not sure what I call a water level indicator really is, but what else would it be ? The thermistor controls the temp, so I'm not sure about it.
I think that the round unit that protrudes into the tank is the limit switch; why would you need anything to indicate water level (well, to indicate a dry tank, but I don't think that's it) on a coffee maker such as this one ?
So, it looks as though a hot wire from the switch would hit the brown wire to the thermistor and also on of the whites to the lower heater, the white to the element would tie into the black from the thermistor, and now I'm stumped. The other end of the element doesn't indicate that there was ever anything there; if I take the white plastic from the element post that the white wire's on, there's a clear plastic covering over that, so it looks like the element is tied in some other way or I really pulled a silly stunt ! It seems it would work fine if the black from the limit switch went to the terminal that looks as though nothing was ever there, because then, with the blue from the switch grounded, we'd have a complete circuit that looks half-way right.
Thanks for all the help. I really hope you all don't give up on me !!!
BTW, this is a 120V unit.
What is this ? Not sure if it's a limit switch or what. I can't get any kind of reaction from
it; it's in a closed state right now. I'm not sure if it's an overlimit switch, but I didn't want to get it too hot in case it's not; water seems to have no effect on it either.
Thanks for the time and effort. I have all of the manuals that have been listed, but really appreciate the help. If I knew what this was, it would help a great deal; the end with the
connector goes to ground, the black wire went ??
I think you all think I'm a freeloader just trying to get free help.
I'm not, but who do I pay ? And I wouldn't mind paying more than one person, but whoever it was that posted the link to the
VPR models definitely came very close.
If you can decide among yourselves, or if the mod needs to do it, I'll be glad to deposit more money in PayPal and pay you all. You've been extremely helpful, and I realize I haven't been that clear and concise.
Thank guys and girls :)!!!
That's not really the correct circuit, there's no varistor in it, and I still don't know what the little unit I posted the last picture of is, if it's a limit switch or has something to do with water level?. I'll keep working on it, thanks to all of you who posted and helped, it's really appreciated, and I'd have paid you all if I had that kind of money; I just paid the last person who posted, because they seemed to persist and really tried to help.
Thanks !!
