Whirlpool series 940 / mdl GU940SCGQ3 goes back and restarts the series of cycles, the Normal indicating light will come on at the restart.
I suspect the membrane in the front panel or circuit board, With out the wiring diagram I can not check the membrane(control buttons). Maybe past experience will answer this.
Bill
Waxahachie Texas
[email protected]
Yes does sound like a "stuck"button within the membrane switch cause constant restarting and/or re-cycling. wire diagram and tech sheet are generally located under the lower acesss panel(unless previous repair ***** returned it). tried looking up the part couldnt find exact model match mine all ended in Q1,Q2, ** Q3, but parts from my models ranged from 110-165
mod#gu980scgs2 starts cycle on normal and continous starts cycle over and over...sometimes you cannot cancell and drain as button doesnt work and nwill keep restarting. the motor overheats,sometimes it will come on in the middle of the night and run through a cycle....help me....please
Model #GU980SCGB2. After cycle is completed the cycle restarts by itself.
