SOURCE: nunchuck doesn't work for one game
yes it could be a glitch or the bad nun chuck is an older type and dosent work with the new game can u help me with wii problem
SOURCE: nunchuck wii problem
Most likely not a fault with either. Try not touching the nunchuk while the game is powering up, as moving the joystick while the game is powering up can cause these issues. If the problem is still happening, click the Wii Home button and open the Wii Remote Settings at the bottom of the screen. Choose the option to reconnect the remote, and then try again. If this doesn't work, ai am not really sure what is the issue. You may need to send to NOA for a checkup.
SOURCE: my wireless nunchuck wont sync with my remote whats wrong
Return the product and use the Nintendo wired nunchuck. The nintendo wired product is only 19.99 and the cord is not that bad of a deal.
SOURCE: Nunchuck is not working even though connected to wii remote
The sensor may be gone. The best way to test this is really easy and pretty cool to do. Take two candles light them and then place them a little further apart than the wii sensor is. If you are able to use the remotes then the sensor bar needs to be replaced and if ther is still nothing I would try replacing the controller because the infered led's may have gone out. If that still does not work then the sensor decriptor in the wii has gone out. Nintendo should be able to help you with that part. But I do not think that it is the Wii. I feel that your sensor bar is bad.
SOURCE: How can you use the nunchuck to play zelda tp?
Just plug the nunchuck into the back of your Wii-mote. The system should automatically detect it and let you use it.
Have you tried replacing the sensor bar? Or moving it to a new spot? Make sure it's plugged in all the way and the wire looks good (no bare spots).
