The foam is a product called neoprene tubing and can be found at specialist rubber product suppliers. Google a local supplier. Changing the grab bar rubber is easy just use hot soapy water but the handle bar is a problem as the foam is fitted before assembly and it would require disassembly to replace. This is not easy as the handle is riveted on and has internal parts to operate the handle locks. You can buy a special glue for repairing wetsuits to fix the split and stop it opening up further.
See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website. And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
html Bike grips and stroller handles work the same way. I just used this post on e-how to replace my maclaren triumph foam handles. Works like a charm - and it's sooo easy!! :)
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
