The water line inside of my ice maker has a leak. Not the line from the wall, but the plastic tubing that runs along the bottom, up the back, and into the insulation. I have found the part on line, but wanted to find out if it is difficult to replace and how I would do it. Thanks for the help.
Take off the back panel, the water line plugs in from the back. The icemaker has mounting screws, but there's a thermal mastic that kind of glues it to the evaporator. You don;t need to remove the icemaker to change the water line, I would put the screws back in and leave it. Don't force the icemaker from the evaporator, it might damage the evaporator.
call 1-800-779-2747
[email protected]
http://www.u-lineservice.com
Same problem, water drips from beneath the ice maker inside the cooling area. This water eventually freezes and turns the whole ice maker compartment into a block of ice.
My BI 95 leaks under the ice tray as well and turns into a big iceburg. I tried to remove the icemake by taking off the screws and couldn't get it to come off
