I have a Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os
Dear sir
I am having an hantel htp-800a cdma wll fixed wirless phone and i want that to be instaled in vista operating system(laptop).How can i do ?
I have a CDMA-2000 1X Wireless Local loop Phone HTP-801. I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os
I have garuda fixed wireless terminal it model no-htt 801.it does not install windows vista
Follow the link given below and download appropriate drivers for ur phone model which works with any OS ..... For more information and support (Regarding FWT/WLL )Please dont feel shy to write to [email protected]......... My sincere advice is plese dont swith ur Internet connection from BSN to any private operators (Especially AirTel and Reliance)
http://www.huawei.com/mobileweb/en/doc/list.do?type=-1&id=4181
I have a huawei Wireless Local loop Phone . I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help m
Hi
I have a Garuda phone its pantech htp-801 with data cable and i got the cd with cable
and I hv vista home premium 32 bit on my pc and internet is fine working on it
if u have facing some prob with same then try it with hentel htp drivr which come with it
......I hv recieve the net surfing speed aprox 80 to 130 kbps and 10 to 21 downloding speed
thanks
cd134u
Download the driver file form http://delhi.mtnl.net.in/services/FWP_PANTECH.zip
Since the drivers are not available for any os except xp.so better option is to run the drivers in compatibility mode. for that,just go to the driver folder in the disc provided, now right click on the setup file.go to properties,there you will see a compatibility tab there is an option about "run this in compatibility mode" now select xp from drop down menu,and install that..its done.
Please change your windows or convert your vista to xp....... bcz vista :::::::: a very slow working windowsss....
Ok
the problem with the hantel modems is that they made them for only bsnl and other corporates, so you wont get drivers for each os
like even they wont work on vista, linux, unix , solaries
ie other than windows 16X , 32X os they wont work at all
solution is:
1. ask BSNL for other modem or facilitate you to let connect with some other company's product like
Acer, Micronet or etc whose driver is avilable, a rather good non tech solution for basic users.
2. solution 2 is that install virtual mac for vista then install xp on that and then run net.
or else
can't help it.
I have a cdma2000 fixed wireless phone
i can connect it with internet only using widows xp but can't use internet through
this phone by using windows vista. please tell me solution that how can i download
free driver for windows vista
Any solution found for this issue?
Hi
I have HUAWEI FWT Wireless Modem Driver. It doesn't install on Windows Vista Home Premium Edition.
What should I do??
Give me bsnl wll internet activet no.
Hi . all of u , i m using hantel htp=800a WLL phone for net of bsnl connetction
so i want vista drivers of this wll phone cdma2000
SOURCE: hi--hantel usb drivers for vista
I have a Hantel phone (CDMA-2000 1X fixed Wireless Phone ). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os..please tell me a link.........
i have garuda connection.
Set is CDMA-2000 1x wireless local loop phone HTP-801
and i need hantel usb modem's driver for vista.
plz tell me about the solution by mailing me at [email protected]
I want vista drivers for hantel 801 handset
Is it possible to aquire drivers for hantel usb modem vista edition
TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
driver hantel vista http-800a
dear sir
I am having a hantel htp-800a model cdma wll internet phone and wanted to be instaled in vista operating system (laptop).How can i do this ?
i need HTP-800A modem Driver which support Vista .
need to download
I have the same problem and waven I couldn't find the official website for Hantel
Please help in installing modem driver of cdma hantel set on vista
Please describe the specifics of your problem below. We'll add
your post as a comment to devvrat's How to install driver of HANTEL USB Modem on vista operating system problem, and notify you when a new solution is offered.
Installation of HANTEL USB Modem in OS VISTA
mtnl gave me data cord with promise that HTP-801 works successfully with USB Data Cord. But now they say that it does not. They refused to buy back the data cord too. should not they be giving me the latest instrument which shall work on vista business os. Peekay
I have same problem as ""I have Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os
hentel usb modem is not taking driver from the driver cd which is provided my the mtnl when we took the connection but its not working in windows vista.
vista 64bit operating system
How to install driver of HANTEL USB Modem on vista operating system and notify me when a new solution is offered.
moden usb
huawei wll fwt USB Modem Driver for window vista
yes the same problem
i am ratish kumar
[email protected]
jgghhfhfhfjh
want to install the dsl mtn modem which was running on xp but not working for vista
i dont know to install for vista
i have using CDMA-2000 1X Wireless Local Loop Phone HANTEL HTP-800A. I am trying to access internet through this phone but it is not possible in any Vista operating system . Now i am using Vista multimedia version.
Can anybody give me the solution of this problem?
i too have same prob, i've got telson handset and bsnl connection ,vista doesn't recognise the driver when connected, help...
please help me how can i install my modem on my computer as cd given by sanchar hut only has software for windows 98se, 2000 ,xp.
i have window vista on my computer help me its urgent
I have purchased a hantel usb modem model no 801 but i am not able to install it in windows vista so please give me a sollution
i am not able to install the drivers of CDMA-2000 1X , model no. HTP-800A for my windows vista OS, as it works on WINDOWS XP .
so i need to install it on vista
please send me the solution .............my id [email protected]
bbb
yes i have the same problem plz send any information to [email protected]
for god sake please send me the solution................ my id [email protected]
cannot find any alternate wizard for installing HANTEL MODEM.
How can i intall huawei FWT,HUAWEI C2860 AND HAIER D200 ON VISTA operating system?
I have a Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801.i want to connect to the internet from window vista it can only connect through win98,xp and 2000 please help me
I have a Wireless Local loop Phone .I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. P
I am also have the same problem...
I have a Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os, Pls send me solution [email protected]
