Sony Walkman NWZ-S616F MP3 Player Logo
Posted on Apr 20, 2008
Can't load movies or videos
Can you tell me how to put movies and videos on my MP3 S616F
  • 5 more comments
  • Anonymous May 12, 2008
    how to download videos
  • Anonymous May 26, 2008
    I had the same problem. The Sony tech support told me I had to buy their software to load videos. They would not tell me how much it was until I loaded some other software first.
  • Anonymous Jun 11, 2008
    how do you convert it to mpeg4
  • Anonymous Jun 21, 2008
    When I try to add a mp4 music video i get the message the file type is not supported. How can i fix this?
  • Anonymous Jun 22, 2008
    cannot see the movies
  • Anonymous Jun 30, 2008
    i dont know how to put videos on my NWZ-S616F
  • wpanther16 Nov 12, 2008
    i tryed loading movies and it wont work
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
138
Points
After many hours of fruitless endevour I've finally found the answer. You have to download Media Manager from Sony then upgrade to Media Manager Pro for £8.20. It seems a bit much to spend £100 or so on a player that doesn't come with supporting software but it was better to pay the £8.20 than splash out another £100 on an iPOD. Media Manager Pro automaticaly converts your videos when you drag and drop them to the device. It takes a while ( a 3 minute music video took 20 min ! )
but at least it works and my daughter is delighted (and so am I )
A
Anonymous
I had the same problems, but it turned out not to be a big issue at all. Windows Media Player and the Sony tool would moan about ANY .mp4 file that I tried to copy over. I checked all my encoding options. Everything seemed good.
Eventually I just used Windows Explorer and copied the files directly onto the Walkman. Everything worked perfectly first time!
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on May 20, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
2682
Points
12
You have to download the video and convert it to MPEG4 or AVC format if it isnt already then you can just drag and drop
4answers
What is the best program to use to put movies on my player?
As for me, i all through use Daniusoft video converter suite to convert various videos even Movie DVDs or HD videos to sony walkman-friendly format, and then put them to my Sony Walkman Video NWZ-S616F MP3 Player for watching ...
tip
Watch DVD Videos on Nokia 5800, N97, Sony walkman (NWZ-S616F, NWZ-S618F) mp3...
Obviously phones don’t have DVD drives, so to watch DVD on a phone like Nokia 5800 you have to convert it into a video file on your PC then drag it into your phone. This article will show you how to Rip Movie DVDs and Convert videos like YouTube video, HD video(.MKV/.Mod/.M2ts/.tp) to Nokia 5800, N97, Sony walkman (NWZ-S616F, NWZ-S618F) mp3 player for watching.
The leading role of this article is Daniusoft video converter suite, it is already optimized for output setting for mobile phone, Sonywalk man in its profile. Very easy to use, like the follow illustration:
Oka, without further ado, let’s cut to the point to get things work
First of all, Download Daniusoft video converter suite, after installing it, you will get two software DVD Ripper and video Converter.
Next step, Run Daniusoft Best DVD ripper to rip movie DVDs and convert videos to Nokia 5800-friendly format. The nifty DVD Ripping software has all essential functions such output profiles, parameter settings and video edit. The detailed conversion process are show as below:
1. Insert your DVD disc into your DVD-Rom (Ensure that you have sufficient space on hard drive to store the DVD). Click ‘Load DVD’ button to add the DVD file. You can also click ‘Load File’ to add DVD/IFO from your hard disk.
2. Select profile “Convert to -> Mobile phone -> Mobile phone video (*.MP4)”.
P.S. If you wanna extract play back music from DVDs and convert to Nokia 5800, Sony walkman (NWZ-S616F, NWZ-S618F) , Just Select profile “Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)”.
3. Click “Settings” to tune codec parameters like Bit Rate, Video Size and Aspect Ratio.
4. Click “Edit” to edit the video in effect, length, size and watermark.
5. Click the protruding button on the right bottom of main interface to start the Movies DVD to Nokia 5800 conversion
Using Daniusoft Best video converter to Convert video to nokia 5800 is as easy as Daniusoft DVD Ripper
1. Run Daniusoft video converter and load your HD video files.
P.S. If you wanna extract play back music from videos and convert to Nokia 5800, Sony walkman (NWZ-S616F, NWZ-S618F) , Just Select profile “Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)”.
5. Click the protruding button on the right bottom of main interface to start the videos to Nokia 5800 conversion.
Now, you can connect Nokia 5800 to computer and copy these converted DVD videos to your Nokia 5800. To this analogizes, you could easily convert DVD videos to your N97, Sony walkman (NWZ-S616F, NWZ-S618F) mp3 player . Using the video converters well can cover the boring journey on a bus or a plain with myriad Christmas happiness and fun.
on Dec 28, 2009 • Cell Phones
3helpful
4answers
How do I load a dvd onto my walkman.
First off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it loads them onto your mp3 player as long as it?s connected, this program will also allow you to download YouTube videos and put them on your mp3 player too.
2helpful
3answers
I have a sony nwz e435f how to put video in it ple help me
omg i took me about a year to figure it out but i finally got it, i'll tell step by step.
1. you need a video converter because the walkman needs .mp4 files (i use Daniusoft video converter suite, it can convert various video even Movie DVDs to sony walkman-friendly format).
2. download ur files then plug ur walkman in and then go to start- my computer- walkman- storage media- video
3. go to start-my documents- then try to find ur .mp4 video
4. drag and drop the video file to video on ur walkman and ur done!
same thing with pictures except u go to pictures instead of videos and then drag and drop the file
sorry if u dont understand it, its kinda hard to explain :]
NWZ-S616F?
Go to Jodix.com and download the video converter for free then after it converts transfer the .mp4 video to the viedo folder on your walkman
2answers
Loading video to my sony NWZ-E436F.
I just got it to work!
I modified the mp4 file using awesome program called ‘SUPER’ (a video/audio conversion program) I did two things.
1) Put the video size to 320X240.
2) I put the the bitrate to 1,008kbps (the .pdf manual on the CD that came with the player states that it can handle mp4 videos up to a max 1,024kbps).
2answers
Problem relating to the play back of videos
You can use the Sony Media Manager to convert your videos. Make sure the mp4 files are: .mp4 video files that are Q VGA size (320x240) and conform to these
profiles: MPEG4-Simple P rofile, A VC Baseline P rofile v1.2, v1.3.
-Tha Mp3 Doctor
2helpful
4answers
Nwz-s616f
u first convert the vedio into mp4 format and place it in the vedio folder of ur ipod if it does not play first convert the original vedio into mpeg format and then convert the mpeg file into mp4 and place it in the vedio folder
1helpful
2answers
I have aproblem with my sony walkman
A big problem with the Sony-NWZ-S616F is that they give you squat for conversion software. What you need is Xilisoft Video Converter Ultimate - Under the pre-set conversion options select "iPod (320x240)MPEG-4 Mini" than RENAME it make a new preset with say "Sony-NWZ-S616F" as the description. Don't change any settings either as it works just fine the way it was setup originally for the Ipod and I found that increasing the settings only makes it worse (in audio you lose a channel if you change anything and in video there is no real quality change it just takes longer to convert and wastes space on the player) - I have Ratatouille, Smokey and the Bandit, Surfs Up, Space Chimps and a few other full-length movies in mine. SAVE and CONVERT all your movies in your PC's hard drive and ONLY put in your player what you want to watch at the time and ONLY transfer 1 converted file at a time using a true USB 2.0 cable. IF It's too slow when transferring you will get an error that it was unable to copy the file. If you try to send over more than one file you might also get the same thing. It will take you about 45 minutes to convert an .AVI to a .MP4 but at least it will work on your player now..
MUSIC: As to getting .MP3 files in it just use Windows Explorer or My Computer and manually copy them into the MUSIC folder on the player.. I found that Windows Media Player does not like to transfer files with this player like they say it should.. tried MP-10, 11 it didn't matter..
[email protected]
Movie downloads and play back
i have the same one but its stuck on the startup menu whats wrong?
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
