My Horizon Advantage E53 Elliptical has stopped rotating smoothly. It is very stiff now. Before it happened it was knocking really loudly and then the noise stopped and it became very stiff. Any suggestions how to repair it? Thanks.
It's probably the bottom bracket bearing. Exercise bikes typically have really, really cheap bearings in them. I have the same problem on my Horizon M4 with a lot of bearing chatter when doing standing high resistance.
Steve, the Ex-79 should be very quite. I am surprise to learn yours is making Squeaky Noise. I think there was some problem with your assembly. How long do you have this trainer? does is make sound when you put your weight on a specific footpadel (like left or right)?
My temporary solution would be to lub up your trainer. Please call horizon regarding you issue on 800.244.4192 (or you can email: [email protected]).
I just fixed the problem on my 430. Somewhere on this forum someone suggested that the dollar size cover on each side of the flywheel cover be removed and the bolt tightened. You will need a socket wrench. It took less than 5 minuted and whamo. Problem solved. Thanks to the individual with that input. Good luck
Sounds like you a bearing in flywheel is failing need to call Accell Fitness of North America @ Phone:
1-800-667-1020 they are the distributors of Tunturi equipment
