Loud pop, no picture, high pitch sqeel, 47" vizio lcd 1yr old
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
SOURCE: Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted
due to a power failure or fluctuation. Here's how to determine which is which:
SOURCE: loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: Vizio model no.P50HDM, loud pop then no picture. Green pwr ind on
P50HDM, loud pop then no pic...
I also have a vizio 42" lcd tv. One night, I heard two or three loud pops as if something had cracked. Screen now only irradically shows random noise. Sound is fine, just no picture. TV turns on/off as usual. Any body seen this or has a resolution?
I just had the same problem: loud pop and no picture
