But you still have not verified that the hose is not kinked from the internal T where the water splits between the front water and ice maker. When you said you removed the solenoid, the water should have been pouring out. Seems to me a blockage between the T and the solenoid.
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
It sounds like the plug-in for the solenoid valve is not making contact with the terminals on the solenoid . You can either buy a new connector or cut the plug for the solenoid and crimp 1/4 inch sta-cons (insulated type) to the wires.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
try to ohm out the solenoid if it (beeps) or ohms out then the solenoid is bad. The laser is first than there is a switch in the gear on the rotating fingers that eject the ice that sends power to the water solenoid.
