Hi. I have a Hoover Wind Tunnel Deluxe vacuum, and the rotating brush does not spin any longer, but still has air suction. Cause ?
Sincereley,
Teresa T.
[email protected]
I also have a windtunnel. My agitator brush won't revolve except in the highest setting. I have replaced both the belt and agitator without luckI also have a windtunnel. My agitator brush won't revolve except in the highest setting. I have replaced both the belt and agitator without luck
You can't post conmments that contain an email address.
Replacement Brush Roller, Fits Hoover UH70400 Windtunnel Air Bagless ... A brush roller on your vacuum is really like a broom for your carpet, that gets all the ...
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Do you have suction at the hose end, if you do then it may be clogged at the inlet by the brush roll. Is the filter cartridge clean? If it is clogged and air can't pass thru it, then you will have no or low suction. Might also check the belt to make sure it is turning.
