Baumatic BWE40 Wine Cooler Logo
Posted on Sep 28, 2010
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3075
Points
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
  • Susan Crowley
    Susan Crowley May 10, 2014
    Is it safe to leave the wine fridge switched on when showing E2 . Does the code E2 indicate which sensor it is? Thanks
I have an E2 error code on my Hoover Wine Cooler. It is working fine and cooling but this has been happening for a while
https://www.google.com/search?client=opera&q=I+have+an+E2+error+code+on+my+Hoover+Wine+Cooler.+It+is+working+fine+and+cooling+but+this+has+been+happening+for+a+while&sourceid=opera&ie=UTF-8&oe=UTF-8 Defective defrost probe
Sep 18, 2018 • Furniture
BWE40 wine cooler. Is it safe to leave it switched on when code e2 is showing? Does code e2 distinguish which of the two sensors need replacing? Thanks.
e2 is a temperature sensor error code.
You would need a multimeter to test sensor and control board.
Either could be the problem
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
2answers
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
E2 error code on marvel wine chiller
Download the PDF manual for your model online then follow the steps.
Danby silhouette dwc276bls e2 error solution
Hi There,
The E2 error codes indicates there is an problem with one of the sensors.
Please contact our customer service department for information on repair.
1-800- 26- Danby
Thanks!
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
3helpful
2answers
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
12helpful
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Top Baumatic Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
