Duracraft DY-012 Tower Fan Logo
Posted on Sep 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i clean my Duracraft Tower Fan Kaz Inc DY012
Ted Poineau
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Sep 02, 2012
Ted Poineau
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
9354
Points
18
I just figured out how to take off the back of the DY-012. You know about the 2 screws on the top, in the 'handle' area. But there is a third screw on the bottom. It is hidden by a small button-sized piece of plastic used to cover the hole the screw is in. This piece of plastic has a pin-hole that you can stick a pin (haha) or a paper clip in, to pop it out. After the 3 screws are out, you pull the back away from the front starting from the bottom, and when you have loosened both sides of the back, you pull down to remove it from the top. You should also see a small **** at the top. Stick a very thin screwdriver or knife in it to help unclip the back from the top. Once you have access to the inside, you just have to figure out the order in which to remove screws to have access to the harder-to-get-to screws. I must say, the plastic cleans VERY easily! My fan was covered with nicotine which accumulated extra dust and dirt, and it now looks brand new!
Allan Schramm
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Apr 19, 2022
Allan Schramm
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
1784
Points
Thank you, Ted Poineau. 10 years after you first posted the access to the back of the fan it has come in handy once again.
Anonymous
Level 3:
  • Master 490 Answers
  • Posted on Sep 30, 2010
Anonymous
Master
Level 3:
Answers
490
Questions
0
Helped
151257
Points
1426
Blow it out with compressed air from a can or (better) with a compressor. If the grill is removable you can top rack dishwash it. farmerbear at FixYa.com
I am looking for a replacement electric motor for a CZ1200 Duracraft Fan heater
duracraft model cz 1200 Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags
Jan 3, 2010 - Duracraft CZ 600 oil filled fanned portable heater and has two switch on end for different watt ... It is white portable electric,but it has oil in it, do . ... looking for replacement parts for a Duracraft model s6436 sander I am looking for a ... I need replacement moter for Duracraft Model DS1600 fan can I get a replacement motor? Where can I find parts for a Duracraft window fan ...
Aug 16, 2010
Duracraft User Manual
Sep 24, 2009
duracraft fan parts Questions & Answers (with Pictures)
Sep 4, 2009
SOLVED: Can't get at the fan to clean
Apr 14, 2008
More results from www.fixya.com
Fan fuse location
There are generally 2 Fuses associated with Honeywell or KAZ Tower Fans... One Fuse is in the Electrical Plug Connector and the other Fuse is on the main Circuit Board.
Where is the fuse on a honeywell quiteset hy-108
KAZ Inc. has franchised the use of Honeywell's company name to manufacture/market this KAZ OEM HY-108 Tower Fan. The small 2.5A fuse you are looking for is located inside the 2-Prong Electrical Outlet Plug. This tiny 2.5A Fuse can be hard to find as a replacement in retail Hardware Stores, but see if you have an old LONG string of indoor/outdoor Christmas Lights... some of these Christmas Lights Strings may have the correct 2.5A Fuse you need. IMHO, it's strange that KAZ Inc. did not put instructions in the Honeywell HY-108 Owner's Manual where the Fuse is located!
I need the plastic support piece that mounts to the base Model #DS1600 duracraft oscillating fan My piece is broken
You will need to contact KAZ for your part at
Telephone
1-800-477-0457
Call center hours
Ordering: 24 hours/7 days a week.
Customer Service: M-F 8:00AM-7:00PM EST
Mail
Kaz, Incorporated
Attn: Consumer Relations
250 Turnpike Road
Southborough, MA 01772
Outside of the U.S. and Canada
Asia Pacific [email protected] Austria [email protected] Benelux [email protected] Central & Eastern Europe [email protected] France [email protected] Germany [email protected] Iberia [email protected] Italy [email protected] Scandinavia [email protected] Switzerland [email protected] Turkey & Middle East [email protected] United Kingdom [email protected] All Other Europe [email protected]
Retailer and Dealer Inquiries
Send email inquiries to [email protected]
Minimum order requirement for accounts.
3helpful
Our duracraft portable fan is humming and not moving? what is the problem and can it be fixed?
Sounds like the armature needs to be cleaned. Dirt can build up on the ends of the motor shaft that operates the fan and where it is held in place, the dirt can actually stop the fan. I would spray both ends of the motor shaft with WD40 and rotate the fan by hand until it is free. This is the cheapest thing to do in order to try and get the fan running again. The problem may be worse than this, but it is a good place to start.
2answers
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
1helpful
2answers
Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
8helpful
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
Top Duracraft Dryers Experts
Leakfixr
Don A
Don A
Are you a Duracraft Dryer Expert? Answer questions, earn points and help others
