THIS IS NOT A DIY JOB !!! See your local Refrigeration Mechanic/Engineer who will have the right equipment/knowledge AND correct refrigerant gas to do the job ... ok
Some older units will require MODIFICATION before this can be done !!!
the driver fro the monitor will be given with your computer if not contact your dealer
you have the right to keep f the drivers with you
if the dealer didnt gave the drivers with the computer you should ask for it and he must give you
if you are looking for wrd to downloading drivers you must specify which monitor you have and the vga card (graphic card)
if are using winXP, click start button - control panel - network connections - check on dial up networking or DUN...right click on it and select properties...check the phone numbers, the username with password. make sureudsure domain has @domain.com
