SOURCE: Mac OSX 10.4.11 won't print to Ricoh Aficio CL2000n network printer
As an update:
I actually had a Ricoh tech come out to my house. It was a warranty service - I was very impressed! He did some fiddling around, said that there was no problem that he could detect but... after he left the Macs can print to the printer no problem. From what I can recall, all of the settings were identical to what they were in the first place on the Mac side.
I still can't get my linux machine to print there but it is a low priority and I am really not trying very hard.
I wish I had more enlightening input.
SOURCE: Printer will not print in color
To select a specific document to print in color, open the document,
Photo, etc, to print, select "print", then select "printing
preferences" in the dialog box, select "color". This will print that
specific document in color, but the setting will default back to
B&W
Now, just FYI,
You absolutely need to set the default color, in your printing preferences - usually to Black and white -to save extra costs. The default setting is ALWAYS color when the driver is installed.. so even if you are printing a word document, the printer will "make" black out of the other colors, thus costing a lot of extra $$. Your settting has apparently been changed appropriately.
This is how it's set the default color should you ever want to change it, "right click" your printer icon in "Printers and faxes" select properties, select "printing preferences", and you will see, in the bottom left corner, the color selector, select "B&W", then select "apply", and close your dialog box. EVERYTHING will now print in B&W, unless you select otherwise, or vice versa if you swith it to color.
I hope that clears it up. Please rate my response
SOURCE: My ricoh printer is not printing straight!
if those tips don't work email me at [email protected]. We just had that problem resolved... beleive it or not it was really simple.
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
I am assuming that the printer is connected to a network. Please check the network cables to make sure they are secured, and then try printing the network setup page. The network setup page will show status connected. If the status is not connected, contact your system support person to make sure the network is functioning correctly
Before sending a job to print, make sure the printer is set to ready state. Ready or Power Saver appears on the display. Please check the status of the toner and check that you are using the correct printer driver.
Printer driver is available on the Lexmark website for download. If no fix, for other information please click the link http://bit.ly/k2p8B5
For additional assistance, please contact Lexmark technical support.
