Lens unit is faulty is not zooming or working properly that why you getting lens error.
you can try to open camera and near lens unit you can blow with pump to remove any dust is not causing this problem if work then good other wise you need replace len unit
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Dear God, It was like a comedy. I got on the whale boat, after having the Canon ixus 60 for 4 years. I've never had any error messages. The whales came 10 feet from the boat and twice raised their head, and no camera, just the beeping and the error message: lens error; restart camera. How do you restart the ixus 60 Canon digital camera, anyone? Please help!! Thanks [email protected], Maui, Hawaii. Aloha!! & Mahalo.
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
the beeping sounds means that your camera lens is stuck. contact the manufacturer (canon), for a possible solution...or they can even send u a new one. My friend dropped her SD630 and had the same problem...she contacted canon, and sent in her camera to be fixed, but it wasn't fixable, so canon sent her a brand new camera. hope this helps.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
