The machine will start to brew a cup and gets through the grinding and
loading stage, then the red light goes solid and the brewing stops before
I hear any water being injected. But, if I run a bit of water through the
instant steam with the heat on, and then start the brew cycle again,
it will complete and brew a cup.
I believe it thinks it is out of water. Perhaps a sensor?
Your idea should be correct. Check all the wiring of the sensor when you removed the top of the machine. The sensor should be there somewhere underneath. If the wires are correct and the rest is not working properly, please contact delonghi for a spare part
First, let me clarify what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Sounds like your coffee grinder is grinding too fine. I would up the size of your grinder. The larger the numbers the coarser the grinds. Also, should descale the machine if you haven't in a while. One of these two things may help.
