Print result p7005
You have something caught in the hammerbank cover. Sometimes a piece of lint, paper chad or some ribbon fabric will get hung in the holes and need to be cleaned out. Remove the ribbon, open the 'mask' as far as you can and look into the hammerbank area to find and remove the debris. Reload the ribbon and run a test print to see if the problem is solved. If not, the problem will usually be a hammer that is not retracting.
I need more info to help:
What interface type? Do you have the Printronix driver installed? Will it run a test print from the driver?
