The TV was fine when I went on vacation. When I turn it on I get sound but the screen is full of white and black small rectangles, looks sort of gray. Obviously the bulb is working. I see nothing but this when I press the device button, but I was able to change to the DVD and hear the sound of the DVD I was playing, also the VCR and change channels with the VCR. I did this because I can remember how many times to push each button.
In any device mode I only hear the sound. I have tried the system reset twice and disconnected the powder once.
Any suggestions? I can be reached at [email protected] if you need an email.
Regards
Gary
Good Day, gary;
It sounds like the TV has a bad formatter board. This board is not available from the factory, it must be repaired.
Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002). Remember FMT PCB is not available.
Good Luck, Big Irish.
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
