Nintendo Wii Console Logo
Posted on Dec 29, 2010
Just bought the cyberbike and the pedals dont work....please help
1 Related Answer
Anonymous
  • Posted on Jan 08, 2011
SOURCE: how do i get the
Hi
had this problem too!! they didn't tell you this in all the instructions! it took me a while to work it out.
What you have too do is when you start the game and you are actually in the game, (you are past the advertisment bit) you have to have your bike switched to gamecube as your lead is connected to the game cube section. you can then have to select the game cube remote this means you can use the bikes controls rather than holding the wii remote.When you have clicked on the game you want you then have to switch the bike back to the cyber bike you can then pedal doing it this way seems to set the bike for use.
i have tried many combinations and this has worked!
the switch i am talking about is the switch on the main part of the bike controls at the bottom in front of you!
good luck i hope this made sense and it works for you!
Pedals keep slipping on the nintendo cyberbike
Try tightening them, or take it to nintendo for a repair
4helpful
Pedal slipping
same problem on my, the belt inside worn out, need replacement, the belt spec. is 280J6, but you need Tri-Wing head security bits to open it
Do you need a cable to connect the cyberbike to the wii console
It should be able to connect via wireless. Simply switch on your Wii console, insert the disc and Cyberbike will connect via wireless access, just follow the simple instructions and you're off.
Do i have to use buttons on the handlebar of the cyberbike? or just to pedal and steer the handlebars?
Hello Tatyana, You mostly need to steer and use the pedals. Depending on the game you play you may have to use some of the buttons - for example, in the Cyberbike original game you can use the a button for jumping over obstacles. You can also use the break to slow you down.
Please note that we do not monitor this forum regularly you can ask us questions directly at [email protected]
How do i stay on the cyberbike she keeps getting off i cannot start on my journey
I am not sure if I understand the question? In order to stay on the bike, you need to pedal. Once you stop the caracter gets off the bike.
2answers
Can't get my Cyberbike to work. Bike will not come on. It is only allowing me to use wii remotes with nunchucks. I would like to use the bike while playing the game. Is there a manual for setting the...
Hello, Yes, there is a manual, it can be downloaded at www.cyberbike-thegame.com click on the support section. It is likely that you have a defective handlebar if the Gamecube controller is not an option. If it is the case, we will send you free of charge a replacement. Best way to proceed is to send us an e-mail at [email protected]
Hi Nintendo, my cyberbike does´nt start.
take the cover off the back of the remote you will see sync button go to the game and open the litter door in front and push the sync button at the same time'
(I hope i help you out)
Hi I am having trouble connecting my cyberbike to the mario kart game, has anyone had success with configuring the bike to the game or can help me to connect them together. Thanks
Look into http://www.fixya.com/support/t7615389-get. It'll work definely well with you Cyberbike paddling as speed control as well! Oh a word of warning, it's very very tiring to bicycle with 'Mario Kart' - an 'extreme excercise' NOT Recommend for old forks or 'light hearted' person!!!
PS. Wants more, the Cyberbike also supports 'Need for speed - Undercover' & 'Donkey Kong' !!!
Have fun...! As I'm cycling everyday with my Cyberbike Kart...
Rgs,
JJStarBug
Wii cyberbike doesnt start.
habe das gleiche problem weißt du inzwischen wie??
5helpful
3answers
New unused Wii Cyberbike not working. Game works fine with remote and nunchuck-but although blue light flashes on handlebars..nothing else does..when I peddle - nothing..etc
With some searching found english manual at http://www.cyberbike.be/sitemapENG_test.html
have to scroll down to support section. Then in the PDF section 4b has section to restore manufacturer's calibration. This worked for us.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
