have a topographic memory stick for province of quebec canada tomtom one 4n00.004.2have a topographic memory stick for province of quebec canada tomtom one 4n00.004.2
You can't post conmments that contain an email address.
Canada is a large country. It will help in knowing the name of the city or county and province where you reside in Canada.
You can choose Comment, here, and type in the location information, so that I or another volunteer answerer for Fixya can provide you with a list of repair businesses in your area which repair Shark vacuum cleaners.
Email or contact these folks and see if they can help you: Mario Necchi Import & Export Inc. Fax: (450) 653-6160 Saint-Bruno, Quebec, Canada E-Mail: [email protected]
Probably the battery pack is worn out or has a "memory" problem. A worn out pack will have one or more cells shorted internally (one or more cells read 0 Volts, and an ohmmeter reads less than 1 Ohm when connected to the 0 Volt cell). If it is a memory problem, it is possible to recondition it, but not simple. You have to remove the pack, then connect a 150 Ohm resistor across each cell and let the battery sit until the cells are completely discharged. You can't just connect a resistor across the entire battery pack because the stronger cells will reverse-charge the weaker ones, which will cause them to short out.
Running the battery too far down will cause the reverse-charge problem, but not running it down at least occasionally will cause the memory problem. (Memory problem explained: the cadmium crystals grow when the battery is charged and shrink as it is discharged. However, the larger ones tend to remain intact on discharge and grow faster than the smaller ones. Eventually they block the ion flow through the battery, so the battery loses capacity. It's called a memory effect because the battery only "remembers" it has the capacity to go down as far as it is habitually used. Running the cell all the way down dissolves the over-sized crystals.)
It is possible you have a problem with the charger. Check for voltage on the charger plug. It should be about the rated output voltage printed on the charger box before messing with the battery.
I have a Shark Cordless Sweeper that needs a new battery too. (Model V1725QC 4.8V) I Googled around and finally gave up and phoned the number on the bottom of the Cordless Sweeper. No problem. The lady did ask me for the "DATE CODE" that is stamped in the silver part on the bottom of the sweeper. The number was 4608 (not easy to read). The battery cost is $16.95 and with Shippling the total came to $22.90. I should receive it in about 7-10 business days. It will be coming from Quebec to BC so that is the total Canadian Price. All model info is on the bottom. The Phone number is on the bottom of your Cordless Sweeper in white lettering on the black plastic towards the rear. The Phone Number is 1-800-798-7398. I hope this will help some other people. Just phone them - best to stick with the Shark Company batteries and they are not easy to find otherwise. No fuss, no muss when I called. No problem ... just gotta wait now. You can also try "www.sharkclean.com" ...
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
you can go online and download a pdf of your manual for $10, at www.sewingmanual.com , I have not spotted one cheaper. If, you go to www.singerco.com you can order a hard copy for $15. What I like about the pdf. is that you always have a copy on your computer or a memory stick or cd,or print it out and you cannot misplace it. Good luck
