The light panal does light up any more
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free.
Good luck and I hope this help.
Byron12020
Control panel as well as lighting in fridge. Freezer light works fine.
my lights don't come on and my temp setting controlls do not light up or work.
The lights on the fridge side do not turn on. The control panel does not light up either. Freezer light works fine. Both fridge and freezer cooling fine.
The lights and the control panel on the fridge side do not turn on. Freezer light works fine. Both fridge and freezer cooling fine.
I had the same problem. I opened the refrigerator door and check to see if the left switch was stuck. It didn't appear to be stuck but after wiggling the switch back and forth, the lights came back on.
refrigerant for sub-zero 690
