I bet you have a Sony VAIO laptop :D Magic gate is the name of memory cards from Sony Corporation. On your laptop magic gate written next to an opening means Sony corporation memory cards may be inserted in that .
Measure the opening where you want to place the Evenflo gate. An Evenflo pressure-mounted gate will work for an opening between 26 and 42 inches wide.
Pull the cross bar up on the Evenflo gate so that the small metal sizing bar is movable.
Place the metal sizing bar into the slot that matches the measurement of your opening. If your opening is not a full inch, round up to the next full inch and place the sizing bar in this slot.
Set the Evenflo gate in the opening with the cross bar facing away from where your child will be. Make sure the pressure points are above your baseboards.
Press down on the crossbar until the metal U-shaped clamp catches the bar.
Test the gate by gently pushing and pulling on it to insure it stays in place.
most likely place is the fuse board ,but a little fairy told me that the magic fuel relay hides in different places so try looking under the bonnet in the power distribution box near the battery
if left is working then check bulbs in right side ,if bulbs ok then renew the hazard switch ,if it still doesnt work then renew the stalk control ,have wiggle of stalk to see if seems to click into place ,also check for feed coming out of stalk when right turn is selected .Then if it still doesnt work look for either the allusive magic multipurpose relay ,but if you cant find that then look for all in one does it all magical relay that covers it hiding place with fairy dust .
Open tail gate. Use the access square inside - pull cable to open tail gate. Remove interier panel - 2 bolts plus 2 screws (2 bolts on handle and 1 screw each side), pull remainder out of guide clips. Now have full access to locking mechanism. Identified a retaining spring had come loose sending guides to shift left (exterior point of view). Place hand in tail gate and move guides over and put spring in place to retain. verify it works and put back together. Handle is the trickiest part as the bolts have to go through the interior panel and afix to the metal tail gate.
That way the T-Rex
cannot reach you. You can also avoid the T-Rex and complete the next
part quickly. Just make sure you stay away from it because you lose
health even if its tail touches you. However, killing the T-Rex makes
you have a clear area and complete the next part at your ease.
Alternative
method - As soon as you collect the Key, immediately jump
out of the ***** and dash to the newly opened gate. The T-Rex will
follow you, but it will not be able to reach you in there. Shoot
it from this safe spot until it is dead. You may need to pop out
a few times to lure it near you, because it may turn its back to
you and go away, but when you see it approaching you again, immediately
run back to your hiding place and shoot it. From these two safe
spots (the middle of the pool or the gate) you can kill the T-Rex
with your Pistols, but be prepared that the process will take some
time.
Jump out of the nest and
use the left shallow part of the pool to reach the other side of
the cavern, close where the dead raptor and the slope are. Go through
the gate you opened by collecting the Key and use the switch to open the gate beyond the pool. Exit and run towards the pool.
The gate is at the far left. If you have not killed the T-Rex,
make sure you use the left shallow part of the pool. Enter the alcove
and use the switch
to open the second gate back where you used the first switch. This gate
gets you back to the upper clearing. (The two lit torches high on the
walls of the cave will help you locate where exactly the two gates are.)
in partition magic ther is an option to hide partitions you probably checked it goto PartitionMagic choose drive properties check for any Hide partiton option regards -Mayank
