SOURCE: Golden Technologies Avenger Bateery Problem
Battery needs replacing when that happens.;
Regards; Aaron
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
SOURCE: moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
SOURCE: I need a manual for a Golden Technologies
Mama take a look @ goldentech.com and if its not listed you can call 1-800-628-5165 for the manual and ask about the part you need or email [email protected] Hopes this helps you
