I would like to implement ip multicast,voice and ip telephony,can an intergrted linksys router perform this with a wireless adapter (NIC) and if so I have never used a linksys router do i user the console cble (CLI) to configure it,
plis advice me.
[email protected]
Linksys has a slim Web server built into their routers and a nice little Web based configuration management interface. You can configure your router to pass or filter IP multicast. Most of the Linksys routers have a filter configuration page where you simply check to filter/pass multicast traffic. As for the VoIP/Teleplhony trafic, you should select one of the routers that allows Quality of Service (QoS) - only some routers support this. The QoS router may recognize the voice traffic automatically but at most you would have to specify the applicaation/ports to give priority to. Again, all is done easily via the Web based management utiility - no CLI needed.
Roger
Print the network
settings page to identify if your printer is connected to your wireless
network:
1. Press Setup on
the printer operator panel.
2. Press the right or left arrow button until Network
Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now
print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address.
SSID should be the name of your wireless network. Otherwise, you may need to
reset the printer's wireless network settings.
How to
reset network settings:
1. Press Setup.
3. Press the right or left
arrow button until Reset Network Adapter Defaults is
4. Press the right or left arrow button to display Yes,
pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark
Wireless Setup Assistant on your Mac.
