Ovens Logo
Posted on Mar 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, curently I am having problems with my stove. It is the slide-in Kitchen Aid Superba model about 10 years old. The oven is losing power but the cook top is OK. I noticed that the fan is not working and I'm assuming something is overheating and shuting the power off. Can you please advise what could be wrong with it? Thanks, Adam
Anonymous
Level 3:
Master:
  • Master 354 Answers
  • Posted on Mar 27, 2011
Anonymous
Master
Level 3:
Master:
Answers
354
Questions
0
Helped
81190
Points
1102
Well my first assumption is that you have a mouse that climbed up and chewed through the wiring. Mice can't resist the heat ,so I would shut off the circuit breaker for the oven (double breaker-220v)
then check the back out to see if you seee any thing ,It could of course be the outlet,or the heat from the oven burning through some of the insulation on the wiring after all those years it could have just failed as well. Check out the voltage to each item if feel comfortable doing so.
We have a Kitchen Aid Electric stove about 10 years old and there was no owners manual left from the last owner. This week we turned on the oven and there is no heat from the elements on both the bake and...
The first thing I would check is the breaker for the oven at the breaker box. I have encountered similar problems and a partially thrown breaker ( or one pole of a double-pole breaker) can cause this. Find your "range breaker" in your breaker box and cut it off then flip it back on. There is a good chance that might fix your breaker. If it is an older house with fuses, then the range would be on two fuses and one of them is blown. This happens to dryers also (if the right fuse/breaker goes, the motor runs but it won't heat)
Hope this helps
tip
Kitchen Aid Oven / Stove Fault Codes
If your Kitchen Aid Oven is showing fault codes starting with F, the problems and solutions can be found at the following website.
CLICK HERE
on Feb 26, 2011 • Ovens
My Kitchen Aid Superba Oven broil doesn't seem to be heating up properly.
Hi, my name is Audrey. I am a KitchenAid employee and would appreciate the opportunity to assist you with your oven. Please send me an email through our customer service address,
[email protected] and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model and serial number, and I would be happy to try to help resolve the situation with your appliance.
1helpful
3answers
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
3helpful
2answers
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
Have a 3 year old Wall oven and the racks don't fit properly anymore.Racks have either shrunk or the oven has gotten wider.
I have the CFES365EB2 Frigidaire slide-in model stove (3 yrs old) and I have the same problem. Did u get any answer ?
We have a Kitchen Aid double oven that is nearly a year old (builder installed.) We ran the self cleaning option on both ovens (top first) for the first time and now the lower oven no longer works. The...
First, I would not delay in notifying your builder by phone and then follow up in writing so that you have a record that you have told him about the problem. Your stove may still be under warranty. He should be able to direct you to filing a claim. One question though, does your oven have a "Sabbath Mode" setting? If so, that could interfere with the regular operation of the oven. What style and model number is the oven?
Jun 21, 2009 • Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
11helpful
2answers
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
