SOURCE: Ecoquest FreshAir - UV Flickering
Need change the whole RCI cell since the u.v light is inside the RCI cell.
SOURCE: bmw 1988 325is engine stops running sometimes -
The number one problem with these cars is with clogged fuel filters. They must be changed regularly. When you say it won't start, do you mean it cranks but won't fire? That could be a fuel pressure problem due to a clogged filter.
SOURCE: turn the ignition on my 330d fuel pump buzzing ok
test power to starter with a voltmeter while someone else turns the key. if you are getting power, than solenoid is faulty. If you are not getting power, than relay or ignition switch is bad. Do double check your battery connections to make sure they are metal to metal contact.
SOURCE: starter motor went out on
Engine Starts: · Fuel Pump secondary circuit shorted to power · Fuel pump relay contacts always closed · Open in fuel pump monitor (FPM) circuit between ECU and connection to POWER TO PUMP circuit · Heated Exhaust Gas Oxygen (HEGO) sensor shorted to power · faulty ECU Engine Does Not Start: · Open inertia switch or inertia switch circuit · Open in or between ECU and fuel pump (This includes open in fuel pump brushes/windings) · faulty ground connection at fuel pump The easiest way to check this circuit is to go to the fuel pump relay. If the relay clicks when the key is turned to the "RUN" position, then the inertia switch circuit is ok. The Pink/Black wire starts from the fuel pump relay and goes two directions. One side goes back to the fuel pump. The other side is the fuel pump monitor circuit and goes to pin #8 at the ECU. This wire should only be hot for a second or two when the ignition is turned to the RUN position. The fuel pump relay receives power on the Black/yellow wire. It comes from a fusible link at the power distribution center. This wire should be hot at all times. If all the above is working as designed, them you probably have a bad fuel pump.
SOURCE: Hi, I have a Hozelock
Hi - I'm Simon from Hozelock. There should be a big o ring that goes between the lid and the tank to make a seal - is that missing ? Also there should be clips that hold the lid to the tank. Both pieces are available as spares, at www.hozelockservice.com - any probs contact [email protected] or @hozelock (twitter) or Hozelock on Facebook. Best wishes.
