Strongly recommend you buy a "snap on" Dodge - Kenwood adapter loom, from your local Auto Accessory store. This will save you cutting any wires, as these adapters are already pre-wired for plug and play and you can put your old radio back in at any stage.
Look for a really small hole in the face plate. Put a tip of a pen into it. Press it in and then it should turn on. If this doesn't work, take it to a place that installs them, they'll help....Usually for free....
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know [email protected]
