The Service light indicator came on on my Sub Zero 632. I looked at potential solutions on this and other sites. The problem was not vacuuming the condenser, or leaky freon or any other listed suggestion. It turned out to be the 12 pack of soda on the bottom shelf of the fridge preventing the door from closing to a tight seal, and therefore causing the compressor to run too long. Hopefully this will help some others with a similar problem.
SOURCE: subzero 632 error code 37
have you tried to do a hard reset by plugging off the unit from wall power for one night
please try it.
SOURCE: sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
SOURCE: SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
SOURCE: Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
SOURCE: subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
