Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
The IXUS 60 is called the SD600 in some parts of the world. You can download the SD600 manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd600#BrochuresAndManuals
The IXUS 60 is called the SD600 in some parts of the world. You can download the manual and more for the SD600 from
Yes. The IXUS 60 was designed to work with SD cards. Cards larger than 2GB are actually SDHC (the HC stands for High Capacity) and will not work in this camera.
Dear God, It was like a comedy. I got on the whale boat, after having the Canon ixus 60 for 4 years. I've never had any error messages. The whales came 10 feet from the boat and twice raised their head, and no camera, just the beeping and the error message: lens error; restart camera. How do you restart the ixus 60 Canon digital camera, anyone? Please help!! Thanks [email protected], Maui, Hawaii. Aloha!! & Mahalo.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
The ixus 60 is also known as the SD600. It's actually quite a good camera. It uses the "NB-4L" battery. You'll need a charger for your camera's battery. Simply remove and place the battery in the charger and plug it in the wall. If you don't have a charger, generic ones are very inexpensive (so are the generic replacement batteries):
canon ixus60 won't switch on
