Emerson Smartset Clock Radio Logo
Posted on Sep 01, 2008
Time Display I recently purchased the Emerson Smart Set iC172 stereo clock radio with ipod docking station. The thing is that the time only is displayed when the motion sensor is activated, and only for a few seconds. Is there a way I can get it so that the time is always displayed?
  • Anonymous Oct 13, 2008
    My clock did not do this the first couple days and now it is only showing the time when the sensor notes motion or when I push the projection button.
  • Anonymous Mar 31, 2014
    how do i set the radio station on my pico life ipod dock clock
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
874
Points
10
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
I want to buy one remote control Emerson Research RC200.
Hi, I am wondering if you ever found a remote, I too am looking for the exact same thing. Please let me know if you had any luck finding a replacement.
Thanks,
you can email me at [email protected]
6helpful
2answers
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
20helpful
2answers
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
3helpful
How do you set the radio stations?
With my ilive ish3 soundbar, you find an unused memory preset, go to the station you want to program, press MEMORY and while the display is still flashing press MEMORY again. Took a bit of trial and error to figure that one out.
21helpful
2answers
I have lost he instructions for my Ministry of Sound hi-fi with docking sysytem and don't know how to tune the dab radio...can anyone help?
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
3helpful
My Emerson IC172 Clock Radio won't recognize iPod
For this type of problem you will need to talk to Emerson Customer Support. They will know if the functions you want will be available to you with the operation of the Clock/Radio and your iPod. The telephone number for the Emerson customer support is 1-800-909-1240. You can call them during the hours of 8am-4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem. Thank you for using FixYa and have a nice day!
92helpful
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Emerson iPod Clock Radio Docking Station #IC200BK radio
I was having a similar problem with my ic200bk stereo dock. After unplugging the machine, replugging it, and allowing the auto set to occur, a timer is activated while nothing else works. I spoke with an Emerson employee about the problem, but he wasn't very helpful. He simply indicated the unit needs to be repaired (which, conveniently, they don't do) or replaced (by only if your 90-day warranty is still in effect...also convenient for me). Bottomline: your unit is **** is Emerson can't (or won't) do a thing about it.
I'm done with Emerson forever.
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
